Discussion topic: Broadband speed
Message posted on 28 Feb 2025 07:41 AM
Broadband speed
Message posted on 28 Feb 2025 07:43 AM
Re: Broadband speed
Message posted on 28 Feb 2025 07:48 AM
Re: Broadband speed
94 Mbps sounds suspiciously like its the limitations of the ethernet cable or the pc ethernet adapter settings
Are you using wifi or ethernet
What device are you testing on
Message posted on 28 Feb 2025 11:46 PM
Re: Broadband speed
Message posted on 28 Feb 2025 11:48 PM
Re: Broadband speed
Message posted on 28 Feb 2025 11:53 PM
Re: Broadband speed
Message posted on 01 Mar 2025 07:07 AM
Re: Broadband speed
@Kym3 the 400Mb/s guarantee applies to the speed to the hub. If you are teasting speeds using wifi it is highly likely but not certain the issue is the speed of the wifi link in your home which is covered by the speed guatantee as factors like the layout and how you home is constructed affect the speeds.
Therefore to remove that possibility ideally run tests over an Ethernet link which supports gigabit speeds. Failing that run a test over wifi innthecsame room as the hub after checking that is out in the open.
Message posted on 05 Mar 2025 07:51 AM
Re: Broadband speed
Message posted on 05 Mar 2025 08:08 AM
Re: Broadband speed
@Kym3 check the cable between the hub and the ONT in several recent cases this had been damaged so no longer supporting gigabit speeds. Any cat5e cable or better should work.
