Discussion topic: Broadband speed
Message posted on 21 Sep 2024 11:50 AM
Broadband speed
Recently checked my broadband speed with a Speedtest app,which suggests my broadband speed is anything from 12 to 18mbps for the last 4-5 days when I've checked. When I check the sky app it says I've consistently every day got 55mbps+ consistently...which one is wrong? as I am not convinced by the sky result at all
Message posted on 21 Sep 2024 11:56 AM
Re: Broadband speed
The best test is using an ethernet device using fast.com
Could you post your router statistics
Message posted on 21 Sep 2024 12:01 PM
Re: Broadband speed
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 37284903 54800051 4 114852 663436 30:27:57 LAN Up 39895644 29813281 0 3556 360 30:29:56 WLAN (2.4 GHz) Up 3964874 1966168 0 1071496 96020 30:28:04 WLAN (5 GHz) Up 13283906 6481683 0 0 46272 30:27:47
These are my router statistics
