Discussion topic: Broadband speed
This message was authored by: Raffles27
Message posted on 20 Jun 2024 06:41 PM
Broadband speed
I have tested the broadband speed and on the sky app and the are both different at home I'm testing it as 68 mb it may not be a lot of difference
Find out more
Message posted on 20 Jun 2024 06:49 PM
Re: Broadband speed
@Raffles27 that is entirely normal the app measures the speed of the connection to the hub when you test speeds on a device you have to allow for roughly 8% of network overheads which the system requires to get data to the right destination. Also a speed test on a device reports the slowest part of the link which can often be WiFi speeds in your home.
