Discussion topic: Broadband speed
This message was authored by: david+disbray
Broadband speed
Please help. My broadband appears
to be really lagging but WiFi checker in the My Sky app says everything is ok ??
Re: Broadband speed
@david+disbray   Please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
Avatar for david+disbray
Level 0 icon
Re: Broadband speed
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 21171665 65042881 0 31894 78662 149:22:52 LAN Up 53060386 17933094 5 5929 29526 149:24:50 WLAN (2.4 GHz) Up 3042623 363726 0 12872 2630 149:23:36 WLAN (5 GHz) Up 31262814 8600531 0 0 40125 149:23:02
Broadband Link Downstream Upstream Connection Speed 79900 kbps 20000 kbps
Re: Broadband speed
@david+disbray
Your router suggests you are getting the full 80mbps download speed for the line. Are you testing your speeds over WiFi or ethernet?
I am NOT a Sky Employee
