20 May 2022 04:14 PM
My download speed is around 700kbps and it's been like this for months.
Last time we called we were told that the underground cables might be damaged (Openreach), however I suspect it's more of a technical issue.
We can't go on like this. We need the Internet for work and study.
Could somebody please help me resolve this problem.
20 May 2022 04:26 PM
Can you post your hub stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
And enter you full postal address below and post the table after removing your address from the image
20 May 2022 05:12 PM
Thanks for your reply.
20 May 2022 05:21 PM
Unfortunately bt wholesale show only 15Mbps copper to the exchange adsl with no superfast fttc
There is no guarantee for adsl apart the ofcom universal service obligation of 10Mbps
Give sky another call and request that they send out an engineer to bring your line up to spec
20 May 2022 05:29 PM
Also what speeds are you getting on 4g/5g in your area. Vodafone, EE and three do 4/5g home broadband subscriptions
21 May 2022 12:34 AM
Hi , would there be any reason for my WiFi to be incredibly slow also.
I'm getting 100kbps upload which is doing my head in.
Constantly dropping etc. Can't even go 5 minutes without it crashing
21 May 2022 07:11 AM
Posted by a Superuser, not a Sky employee. Find out more@Redfordo as advised above post your hub's connection stats see Find your Sky Broadband router statistics
21 May 2022 02:54 PM
Hi,
That post you linked doesn't show me how to get the statistics because it said click maintenance then statistics and I don't have that
21 May 2022 03:14 PM
Sky aren't the USO provider, though: that's BT.
21 May 2022 03:15 PM
On the phone with them now
21 May 2022 03:18 PM - last edited: 21 May 2022 03:24 PM
Outbound speed on ADSL is inherently extremely limited even on a perfect line. 1.4Mbs is the best possible (on 24Mbs inbound): if you could get 15Mbs arriving at your address then you'd hope for around 700Kbs upload.
Thats only to contact sky to bring the line up to USO specs. I haven't linked in the actual ofcom uso as that just specifies excess costs over the £3500'ish
21 May 2022 04:28 PM
Posted by a Superuser, not a Sky employee. Find out more@Redfordo yes you do the link is at the right at the bottom of the maintenance landing page if you scroll down.
21 May 2022 04:40 PM
Posted by a Superuser, not a Sky employee. Find out more@Redfordo You will struggle even more to get a suitable speed if using WiFi I'm not surprised you're getting such a low upload speed.
