Discussion topic: Broadband speed issues
This message was authored by: Ren96
Hi !
For the last two days my hubs been slow it's know started to disconnect also . I've run the speed tests and reset the hub . Speed tests say no issues with the hub but issues still occurr.
is it worth trying one final reset or contacting sky in case it is a broadband issue ?
Re: Broadband speed issues
@Ren96
You could try another reset but if you haven't already you could rry running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for Ren96
Thank you for your reply .
Ive ran the test ans diagnostic as suggested and still says poor performance /is intermittently disconnecting .
ill give Sky a call
