Discussion topic: Broadband soeed
This message was authored by: Chris202411
Broadband soeed
I've just tested the line with sky, it says I'm getting the speed to the house, but I'm not getting 1/10th of the guaranteed speed in the property
This message was authored by: JPR007
Re: Broadband soeed
@Chris202411 What speed are you supposed to be getting?
What device are you testing on? How are they connected?
What software /site are you using to test?
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Avatar for Chris202411
Re: Broadband speed
Hi
I'm expecting 500mb and I'm getting 40mb
looks like it may be a software issue with PlayStation and Xbox so I've switched to Wi-Fi to do updates. Soon as I go back in on LAN it tells me software issue with router.
will try contact sky tomorrow
