Discussion topic: Broadband slow
This message was authored by: patrick+talbot
Message posted on 28 Oct 2025 04:34 PM
Broadband slow
My broadband is running at 51 maps should be 600 + have reset it
This message was authored by: 2muchTV
Message posted on 29 Oct 2025 08:38 AM
Re: Broadband slow
How are you testing the speed of the broadband? If you have a laptop with an ethernet cable, suggest you connect it to the hub and check the speed that way. This will tell you what speed is being delivered to the hub. WiFi speed and range is another matter and will invariably show a drop off to the speed at the hub.
Former Sky HD+, Q and Stream customer
Now TV Sports + Entertainment + Cinema + Ultra Boost @ £33 pm
2 x FTTP lines: Digi £15 pm 900/900 & Aquiss £36pm 80/20
Connected in dual WAN to 3 x Asus XT9 mesh & 2 x Asus RT-AC58U
65" Samsung S92C OLED TV
6 other streaming TVs
