Discussion topic: Broadband router
This message was authored by: Pat182
Broadband router
I keep having to reset it as it keeps losing connection today
Re: Broadband router
@Pat182
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
