Discussion topic: Broadband regularly drops out CV37
This message was authored by: Crash1t
Having issues with broadband dropping out of an evening regularly, usually about 9pm onwards
We have Sky router and all sky online tests show it's fine, once it gets back up!
Despite these checks the broadband still drops out. No issue with WiFi, just Broadband fails.
Re: Broadband regularly drops out CV37
@Crash1t
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Crash1t
Thanks Daniel,
Those are the tests that I've previously run. Ran them again and they don't report a problem, yet every evening the broadband drops.
Sorta makes 'testing' it a bit pointless if it can't detect that there was/is a problem. It's more of an inconvenience than anything.
Guess I call 150.
Thanks again.
