Discussion topic: Broadband problems
This message was authored by: JinkyKitty
Broadband problems
My broadband is not working
Re: Broadband problems
@JinkyKitty
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
