Discussion topic: Broadband password
This message was authored by: Dean19721
Message posted on 12 Feb 2025 07:08 PM
Broadband password
Trying to contact the new password to my phone but it says incorrect tried different letters but still doesn't work
Find out more
Message posted on 12 Feb 2025 07:34 PM
Re: Broadband password
Make sure you are using a 0 (zero) and a letter O if required and also the letter i instead of an L.
The password should also be printed on the new hub if you need to double check what it is.
