Discussion topic: Broadband outage
This message was authored by: ScottGalbraith
Broadband outage
We have been having issues all day with our broadband dropping constantly. We have tried rebooting our router but it only works for a short time before cutting out again
Re: Broadband outage
@ScottGalbraith
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
