Discussion topic: Broadband outage
This message was authored by: Jstardan
Broadband outage
Sky broadband router showing solid amber light
Re: Broadband outage
@Jstardan
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Avatar for Jstardan
Thanks Daniel,
the app has now updated and is indicating "an issue in my area" although the expected resolution in "2days" has created some family anxiety (anyone know where we kept the board games?).
Hopefuly resolved before work on Monday!
@Jstardan You will have stored them in a safe place hopefully! Please also be aware it's an estimated 2 day's, hopefully quicker just depends on what the fault is and how quickly OR can deal with it all!
@Jstardan
Sky normally quote 2 WORKING DAYS as a potential fix time. This is the service level agreement in the UK between ISPs and Openreach for fixing a fault as Openreach claim to be successful within that timeframe in 85+% of cases.
