Discussion topic: Broadband outage
Message posted on 09 Sep 2025 08:53 PM
Broadband outage
Sky broadband outage in Telford, is anyone else having an issue?
Message posted on 09 Sep 2025 09:00 PM
Re: Broadband outage
@MrsLJD1
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
