Discussion topic: Broadband not working
Message posted on 15 Oct 2026 12:43 PM
Message posted on 15 Oct 2026 12:59 PM
Re: Broadband not working
@Keila112
If you are new to the forum, or this is your first post, then welcome to the Community which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
There are reported problems in Edinburgh otherwise…
Use this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault that only affects your address).
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
