Discussion topic: Broadband not working.
This message was authored by: Will1771
Anyone else's broadband stopped working tonight? Sky seem to be their usual unhelpful selves in making this really difficult to report.
Re: Broadband not working.
@Will1771
Two people from the HR9 poscode have posted to say they have no connection.
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
This message was authored by: AdsGray
How do you report an issue
This message was authored by: Me134
Follow the prompts on the service checker and if a problem is found then it will provide a direct contact route to report it. Be aware, the checker can be an hour behind real life events (no idea why). The other options are 150 from a Sky landline (if it's working) or Sky mobile or the phone number or chat options on the MySky app or the website.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
