Discussion topic: Broadband not working
Message posted on 22 Jun 2026 07:29 PM
The broadband keeps dropping out constantly, this has been happening for over a week.
Message posted on 22 Jun 2026 07:30 PM
Re: Broadband not working
Try running this line test to see if it finds any faults:
@DonWee
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
