Discussion topic: Broadband not working
This message was authored by: RobinJames2
We have no broadband since yesterday
Re: Broadband not working
@RobinJames2
Even if you’ve already tried it the first thing to do is use this link to check if there are any broadband outages or issues locally that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Avatar for RobinJames2
My broadband hasn't been working since yesterday, I have work tomorrow and urgently need it!
@RobinJames2
If you still have an issue tomorrow then once aware Sky usually quote 2 WORKING DAYS as a potential fix time because of the service level agreement in the UK between ISPs and Openreach for fixing a domestic fault.
Some repairs take longer, for example when a pole or cabinet has been damaged or Openreach / City Fibre need to dig the road up (once they’ve obtained permission from the local council).
What was the result of the line test you ran from the link posted by @Daniel0210 ?
