Discussion topic: Broadband not working
Message posted on 28 May 2026 06:55 PM
Hi, my broadband is not working out. It should be. I'm paying for sky max and it's still not working. This needs to be sorted out
Message posted on 28 May 2026 06:58 PM
Re: Broadband not working
@Dan3005
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
