Discussion topic: Broadband not working
Message posted on 03 May 2026 10:28 AM
There was a period of 2 hours last night where my broadband says there's no internet connection however the tests on Sky say everything is fine.
This morning it has been working and now I have the same issue in spite of the Sky tests saying there's no issue.
Message posted on 03 May 2026 10:31 AM
Re: Broadband not working
@Charlie+Boy+S-U-A
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
