Discussion topic: Broadband not working
This message was authored by: JohnWhite
My broadband has stopped working . It is an intermittent fault. It has been happening since before christmas. Can some one attend and fix it. The problem seems to be outside of my house. The router has been changes as has the box into the house.
Re: Broadband not working
@JohnWhite
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
