Discussion topic: Broadband not working
This message was authored by: Rebeccab3
Broadband keeps flashing lights not working no Internet has persistently done this for ages
Re: Broadband not working
@Rebeccab3 Define ages, also the links below if you wish to try them!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
@Rebeccab3
If it's been ongoing for a while have you reported it to Sky?
Even if you’ve already tried it, use this link to check to see if there are any broadband issues or outages nearby ~
