Discussion topic: Broadband not working
Message posted on 22 Dec 2025 08:26 PM
Sky TV is fine but I can't get online.
i have a new fibre connection but the internet connection has been poor since it was installed.
Message posted on 23 Dec 2025 08:22 AM
Re: Broadband not working
@Doug30 do any devices connect if they do but you have issues in certain rooms in hour home then the issue is poor WiFinsignal,levels. That is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
