Discussion topic: Broadband not working
Message posted on 18 Dec 2025 07:38 AM
Broadband is not working, 2 Orange lights on the router but your checks claim everything is working ok?
Message posted on 18 Dec 2025 07:42 AM
Re: Broadband not working
@MDelaney
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 18 Dec 2025 07:44 AM
@MDelaney read my post here where I explain that there is upmto an hour delay before the service checker picks up the lost connection. Either wait and rerun the checks or call Sky yourself.
