Discussion topic: Broadband not working
Message posted on 14 Nov 2025 11:10 AM
The broadband has been intermittent at best for the last 3 days. It has dropped off again today. All your tests say that there is no issue but there clearly is.
Message posted on 14 Nov 2025 11:13 AM
Re: Broadband not working
Not our tests @DA72 You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
