Discussion topic: Bognor Regis
This message was authored by: Siamesegold
Bognor Regis
Internet just gone down. All reporting fine on the checker. Router is fine but no internet. Anyone else?
Re: Bognor Regis
@Siamesegold
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
Avatar for Siamesegold
Re: Bognor Regis
All checking back as ok. Will check back again later.
