Discussion topic: Broadband not working
Message posted on 13 Nov 2025 03:00 AM
Test says fine but no broadband/wifi/internet???? Come on Sky!!!
Message posted on 13 Nov 2025 05:13 AM
Re: Broadband not working
@Lady+P66 wrote:
Come on Sky!!!
@Lady+P66
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
