Discussion topic: Wifi not working at 02-25am rebooted numerous times is there a problem SKY ???
Message posted on 13 Nov 2025 02:28 AM
WIFI NOT WORKING DUDLEY WEST
MIDLANDS.......
Message posted on 13 Nov 2025 05:15 AM
Re: Wifi not working at 02-25am rebooted numerous times is there a problem SKY ???
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
