Discussion topic: Broadband not working
This message was authored by: Lucylocket2
My internet is not working
Re: Broadband not working
@Lucylocket2
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
