Discussion topic: Broadband not working
Message posted on 16 Sep 2025 04:30 PM
Need my broadband back on
Message posted on 16 Sep 2025 04:50 PM
Re: Broadband not working
Presuming here that your services aren't restricted due to a missed payment …
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
