Discussion topic: Broadband not working
This message was authored by: Maddox0108
Broadband is not working but service checker says all is good even though it says there's a problem to start with
Re: Broadband not working
@Maddox0108
@Maddox0108
Try running the line test here:
If this is of no help give Sky a call to report it to them.
