Discussion topic: Broadband not working properly
Message posted on 31 Aug 2025 07:33 PM
Message posted on 31 Aug 2025 07:43 PM
Re: Broadband not working properly
@Cassy+1
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
