2
This discussion topic has been answered Discussion topic: Broadband not working properly
This message was authored by: Deborah103
We had the broadband for some time and it still isn't connecting to some parts of the house
This message was authored by: Giggsy1977 Answer
Re: Broadband not working properly
The WiFi reach of ISP provided routers isn't the best unfortunately. You could call Sky to discuss the WiFi max package and get a signal booster (doesn't boost the signal as such, just acts as a repeater to extend the WiFi range a bit). That is an extra charge per month though.
Other options are connecting via ethernet cable where you can and if not, using homeplugs are probably the next most reliable.
Not a sky broadband subscriber
Avatar for Deborah103
Thank you, 🙏
