Discussion topic: Broadband not working ipswich
This message was authored by: LyndaA
Sky broadband not working since last evening, test showing everything ok.
Followed all the usual advice to fix but still not working.
Re: Broadband not working ipswich
@LyndaA   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for LyndaA
Level 0 icon
Yes, done all that and not showing any outage in the area and test says all
ok but router still not working. Only 3 green lights and one amber light.
Have you rebooted your broadband hub ?
