Discussion topic: Broadband not connecting
This message was authored by: Meghna1
My sky hub is all connected but not getting the internet
Re: Broadband not connecting
@Meghna1
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
