Discussion topic: Broadband not connecting
This message was authored by: Betry
The internet light on y sky box isnt lighting up and our internet is down ive tried turning it off and on even changed the wore from the box to the main connection and it weny on for a few mins them off again
Re: Broadband not connecting
@Betry
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
