Discussion topic: Broadband keeps going off
This message was authored by: Steve683
Broadband keeps going off two or three amber lights
Re: Broadband keeps going off
@Steve683
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
This message was authored by: Geoff_L
Does that just lie though?  After running the test tells me everything is great and I'm pulling 14 MB except the router clearly has two greens and a amber rather than the 4 greens.  Having a service checker that doesn't check the service is a extremely poor experience
@Geoff_L The lights linked below!
Avatar for Steve683
Hi thanks for info was helpful to the point of yes it didn't work. Engineer call went straight to the fibre line and disconnected it from open reach box and the green light stayed on which should have gone off.New box and now all good again.
@Steve683 Which box was replaced if you know!
Avatar for Steve683
The open reach
@Steve683 Thanks for replying, let us know how it all works out between your new ONT and the sky SR203 Black Broadband Hub that you have!👍👍
