Discussion topic: Broadband keeps going off
Message posted on 11 Jun 2025 07:45 PM
We keep losing our broadband and it's knocking our devices out we can't use our phones tv computer etc.... the bill is saying paid so we have reset the router and still having problems
Message posted on 11 Jun 2025 07:49 PM
Re: Broadband keeps going off
@Mark5010
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby. Note: the service checker sends routine tests to the hub and won’t necessarily register any issue until the hub fails to respond.
Message posted on 11 Jun 2025 07:50 PM - last edited: 11 Jun 2025 07:51 PM
@Mark5010 Why do you mention that the bill has been paid, have you had trouble not paying before?
You can run the service checker to see if sky are aware of any ongoing problems!
