Discussion topic: Broadband keeps going down
This message was authored by: StephenPearce
Hello, My broadband keeps going down over the last few weeks. Its been up and down today since 12pm ish. Can you do some more checks please. Thank you Steve.
Re: Broadband keeps going down
@StephenPearce
This is a customer helps customer forum and you aren’t contacting Sky Customer Services on here.
If you’re still having problems you may need to call Sky to report it (dial 150 free from your Sky Talk landline).
Avatar for StephenPearce
Thank you for the info. . I didn't realise I was posting a discussion thread at the time, as I was distracted.
