Discussion topic: Broadband keeps dropping
Message posted on 04 Nov 2025 03:24 PM
My Btoadband keeps dropping I have had to go into the office because it is so un reliable
Message posted on 04 Nov 2025 03:26 PM
Re: Broadband keeps dropping
@Galy
Use this link to check to see if there are any issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Message posted on 04 Nov 2025 03:27 PM
Me too. Dropped 7 times on Sunday. Yet service checker keeps telling me the line's OK. If it's the hub, it's not obvious how I get a new one from Sky. How do you even speak to a real person at Sky?
Message posted on 04 Nov 2025 03:31 PM
