Discussion topic: Broadband WiFi not working
Message posted on 04 Nov 2025 01:57 PM
Message posted on 04 Nov 2025 02:09 PM
Re: Broadband WiFi not working
Yep I had the same problem in Ballachulish - frustrating when you work from home
Message posted on 04 Nov 2025 03:18 PM
Use this link to check to see if there are any issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
