Discussion topic: Broadband keeps dropping out
This message was authored by: Sam55xxxzzz
Over the last few days my broadband kerps droppung out, thui is now happening multiple times per day
Re: Broadband keeps dropping out
@Sam55xxxzzz
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
