Discussion topic: Broadband keeps dropping out
This message was authored by: Rebecca3105
Hi,
my broadband keeps dropping out every couple of minutes and then reconnects again, I will have an internet connection for like 2min and then it just drops out again. On the router it is showing two orange lights, the second light starting from the left and the 4th light both go orange. It's very annoying as I work from home and it's effecting my work now.
Re: Broadband keeps dropping out
@Rebecca3105 You can only run the service checker or/and the diagnostic, but dropping to amber light then connection issue somewhere.
Try running the line test here to see if any faults are found:
Avatar for Rebecca3105
Yes I have done all that and initially says there's a problem but then when I run the tests it says there is nothing wrong even though I have no Wi-Fi.
This is what comes up when I run the tests
@Rebecca3105
This isn't a live chat so replies may not be instant.
@Rebecca3105 caesarome has redirected you to sky for help so watch out for that, your pictures take a little time to be cleared so they are not for instant viewing, but will look later at them.👍
