Discussion topic: Broadband keeps dropping out
Message posted on 20 Apr 2024 09:39 AM
The past three days the broadband keep dropping out. I reset the router each time. This works for a few hours and then it drops out again. Others have a similar issue.
Message posted on 20 Apr 2024 06:45 PM
Re: Broadband keeps dropping out
@Bccc Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 20 Apr 2024 09:44 PM
Hello there
I've done that. Four times. This started yesterday and continues every few hours including today. I have to reset the router each time.
The app says there is nothing wrong. Except when I go to it during the router outage. Then it says Sky is having "technical difficulties".
Message posted on 20 Apr 2024 10:15 PM
Keeps happening to us too. Following the steps provided online to fix it does nothing every time. Monthly subscription has gone up a lot recently too. Time to switch provider I think.
Message posted on 20 Apr 2024 10:40 PM
Message posted on 20 Apr 2024 11:32 PM
Mine is exactly the same as others
Message posted on 21 Apr 2024 01:00 AM
I'm having same issue as my internet drops then comes back on and I'm paying so much for it and I'm think going somewhere else if this continues
Message posted on 22 Apr 2024 08:18 PM
Yes. Exactly the same. They even sent me a new router today and it's still doing exactly the same. Orange light comes on, no WiFi but all the diagnostics say it's fine.
Message posted on 22 Apr 2024 09:06 PM
Same here, internet fails, hub flashes Green, goes to steady red then flashes Green again. Help guides do not fix it. Resets in around an hour, happened twice today, once yesterday etc. How do you contact Sky to fix it. Can no longer work from home. Cancel Sky and return to BT?????
Message posted on 22 Apr 2024 09:31 PM
Mine has been the same since yesterday evening, loses connection every 10-15 minutes. Rang sky to be told no issues but I find it funny how so many people are having the same issue so must be a fault their end. So frustrating when trying to work from home
Message posted on 22 Apr 2024 09:41 PM
Same problem here. Nothing changes rubbish service every single time no matter how much more you pay. Broadband drops every 15-30 min. Did the useless steps on the problem solving page, unplugged everything, turned off from mains and still the same problem and no satellite signal on top of that. Service checker says everything OK. Absolutely disgusting...
Message posted on 23 Apr 2024 12:04 AM
Everyone is pretty much saying the same thing. Sky broadband no longer any good; ridiculously expensive and time to quit. So any thoughts on who we should all switch to for best reliability and value for money?
Message posted on 23 Apr 2024 06:42 AM
Message posted on 23 Apr 2024 08:10 AM
Phone lines get faults and need to be fixed which is a fact of life. Imagining its a conspiracy is totally pointless.
- If your connection is down pick up the phone and report it Sky who will get Openreach out to fix it.
- If your connection is running slowly or dropping and coming back while run the connection test while the hub is connected - dont rely on the message generated when it last ran automatically - that can book an engineers check if it finds a fault. If it doesnt call Sky
- Lastly if your connection speed is reported as OK but apps crawl then your issue is within your home and is likely to be a Wifi issue.
Forum members are customers but some of us know a fair anount about how these things work so if you post your hubs stats in a new thread with a few details of the symptoms we can probably tell you what is wrong see Find your Sky Broadband router statistics
Message posted on 23 Apr 2024 08:13 AM
As the original poster I am now giving an update.
The Wi-Fi does keep dropping but the router has stopped going off and on for now. I have done nothing and spoken to no one from Sky. I presume they have either looked into my account or fixed the issue.
it's still a little glitchy on the tv. But I've not had to reset the router for a half a day now.
