Discussion topic: Broadband keeps dropping off
Message posted on 19 Aug 2025 01:46 PM
Message posted on 19 Aug 2025 01:51 PM
Re: Broadband keeps dropping off
@Mariefagan
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
