Discussion topic: Broadband keeps cutting out
This message was authored by: Dazz71
every day your router is losing signal, reconnecting, disconnecting reconnecting, disconnecting
Re: Broadband keeps cutting out
@Dazz71
Not our router. You aren’t talking to Sky by posting here. If you are new to the forum then welcome to the Community which is made up predominantly of Sky customers helping other Sky customers which includes additional help from customers who are Superusers like myself.
It may be a faulty hub but perhaps start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
