Discussion topic: Broadband keeps cutting out
This message was authored by: gemman
Hi i've restarter my router multiple times but my wifi keeps cutting out. Is the problem more wide spread?
Re: Broadband keeps cutting out
@gemman if you mean are other people getting similsr issues the answer is yes but the issue is not caused by one single fault. The recent bad winter wetather does cause issues especially with services delivered over  copper lines. These lines can be decades old and do develop faults which means water and ice can cause the connection to drop.
The problem is Openreach, whose network Sky use, are reluctant to send out engineers until the number of line drops is around 10 a day or the automatic line management systems cannot stabilise the line without dropping speeds below the guaranteed minimum. Basically you can report the ussue to Sky butvthey msy not be able to get it fixed.
