Discussion topic: Broadband keeps cutting off
This message was authored by: HMH
Broadband keeps cutting off and saying fault it happens at least 3 times daily only two green lights are on the box itself and the others show amber lights. I have reset the box numerous times times, I've also checked all cables and switched it off and on also but still keeps happening.
Re: Broadband keeps cutting off
@HMH
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
