6
This discussion topic has been answered Discussion topic: Broadband issues
This message was authored by: GK62
Broadband issues
Hi - we have broadband connection issues. Your checker says it's working but it has an intermittent fault?
Avatar for GK62
This message was authored by: GK62 Answer
Re: Broadband issues
Thanks. I have narrowed it down to security settings on the hub....so far so good.
thanks for your help.
@GK62
As you are talking to other issues can you explain what is happening ?
Avatar for GK62
Have reset the hub but for the pst two days it has been on and off. Even wired connections to hub not working. Sky tool says it is but it isn't!
@GK62
What was the result of this line test:
Avatar for GK62
This message was authored by: Bri-G
Could you please explain how to stabilise the internet connection as for the last two days the internet has been intermittent with the connection shown to be on, then switching off temporarily and then back on tends to be on longer than off. Can advanced settings help ?
This message was authored by: Wayne163
Broadband keeps disconnecting from tv
